ETS-Lindgren 8000-001
Jump to: navigation, search
The ETS-Lindgren 8000-001 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the ETS-Lindgren 8000-001:
The frequency range of the ETS-Lindgren 8000-001 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the ETS-Lindgren 8000-001.
Be careful changing these setting as RadiMation® is no longer able to verify if the ETS-Lindgren 8000-001 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
