ETS-Lindgren 8000-020
The ETS-Lindgren 8000-020 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the ETS-Lindgren 8000-020:
The frequency range of the ETS-Lindgren 8000-020 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the ETS-Lindgren 8000-020.
Be careful changing these setting as RadiMation® is no longer able to verify if the ETS-Lindgren 8000-020 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: ETS-Lindgren 8000-020
- Google image search: ETS-Lindgren 8000-020
