ETS-Lindgren EMPower 7002-004
The ETS-Lindgren EMPower 7002-004 device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the ETS-Lindgren EMPower 7002-004:
The frequency range of the ETS-Lindgren EMPower 7002-004 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the ETS-Lindgren EMPower 7002-004.
Be careful changing these setting as RadiMation® is no longer able to verify if the ETS-Lindgren EMPower 7002-004 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
Value | Allows to select the filter that should be used in the measurement device. The possible filters are described in the manual of the ETS-Lindgren EMPower 7002-004. |
There are several methods in which the ETS-Lindgren EMPower 7002-004 can be connected to the PC. The ETS-Lindgren EMPower 7002-004 can for example be connected directly to the PC, or through a plugincard in a RadiCentre 1 or a multi-slot RadiCentre. More information on how to use the RadiCentre is present in the product manual of the RadiCentre. The settings on the RadiCentre tab can be used to specify how the ETS-Lindgren EMPower 7002-004 is connected.
When the ETS-Lindgren EMPower 7002-004 is connected to a multi-slot RadiCentre, also the slot number in which the plugincard is fitted, should be specified.
Directly to PC | Specifies that the ETS-Lindgren EMPower 7002-004 is connected directly to the PC, without the use of a RadiCentre. |
RadiCentre 1 | Specifies that the ETS-Lindgren EMPower 7002-004 is connected to a plugincard that is fitted in a RadiCentre 1. |
RadiCentre multi-slot | Specifies that the ETS-Lindgren EMPower 7002-004 is connected to a plugincard that is fitted in a multi-slot RadiCentre that also can be manually controlled using the display on the front of the RadiCentre. The slot number in which the plugin card is mounted can also be selected. |
RadiCentre multi-slot Ultra | Specifies that the ETS-Lindgren EMPower 7002-004 is connected to a plugincard that is fitted in a multi-slot RadiCentre Ultra. This RadiCentre Ultra has no display, and can only be used when remote controlled. |
The configuration on the Communication tab should be configured depending on the outgoing connection from the PC. Thus if Directly to PC is selected, the communication settings should be configured as what is actually used between the PC and the ETS-Lindgren EMPower 7002-004 itself. If RadiCentre 1, RadiCentre multi-slot or RadiCentre multi-slot Ultra is selected, the communication settings should be configured as what is actually used between the PC and the RadiCentre. In the configuration where a RadiPower is connected with USB to a multi-slot RadiCentre, which is connected by GPIB to the PC, the communication settings of the RadiPower device driver should thus be GPIB.
If the ETS-Lindgren EMPower 7002-004 is for example connected to slot 3 of a multi-slot RadiCentre which has IP address 192.168.178.95 and is connected by LAN to the PC, the following settings should be configured in the device driver of the ETS-Lindgren EMPower 7002-004:
- RadiCentre tab
- Communication tab
- Communication Stream: VISA
- LAN: 192.168.178.95
The Software update tab can be used to update the software of the ETS-Lindgren EMPower 7002-004.
