ETSLindgren ETSLINK
The ETSLindgren ETSLINK device driver is a Cable which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the ETSLindgren ETSLINK:
The frequency range of the ETSLindgren ETSLINK as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the ETSLindgren ETSLINK.
Be careful changing these setting as RadiMation® is no longer able to verify if the ETSLindgren ETSLINK is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: ETSLindgren ETSLINK
- Google image search: ETSLindgren ETSLINK
