Electro-Metrics EM-6876
The Electro-Metrics EM-6876 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Electro-Metrics EM-6876:
The frequency range of the Electro-Metrics EM-6876 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Electro-Metrics EM-6876.
Be careful changing these setting as RadiMation® is no longer able to verify if the Electro-Metrics EM-6876 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Electro-Metrics EM-6876
- Google image search: Electro-Metrics EM-6876
