Electrometrics 3115
The Electrometrics 3115 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Electrometrics 3115:
The frequency range of the Electrometrics 3115 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Electrometrics 3115.
Be careful changing these setting as RadiMation® is no longer able to verify if the Electrometrics 3115 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Electrometrics 3115
- Google image search: Electrometrics 3115
