Em test CWS500N1.4
The em test CWS500N1.4 device driver is a Signal Generator, Amplifier, Coupler, Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Em test CWS500N1.4:
The frequency range of the Em test CWS500N1.4 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Em test CWS500N1.4.
Be careful changing these setting as RadiMation® is no longer able to verify if the Em test CWS500N1.4 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: em test CWS500N1.4
- Google image search: em test CWS500N1.4
