Em test CWS500N3 (band 2: 500 Hz - 1 kHz)
The em test CWS500N3 (band 2: 500 Hz - 1 kHz) device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Em test CWS500N3 (band 2: 500 Hz - 1 kHz):
The frequency range of the Em test CWS500N3 (band 2: 500 Hz - 1 kHz) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Em test CWS500N3 (band 2: 500 Hz - 1 kHz).
Be careful changing these setting as RadiMation® is no longer able to verify if the Em test CWS500N3 (band 2: 500 Hz - 1 kHz) is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: em test CWS500N3 (band 2: 500 Hz - 1 kHz)
- Google image search: em test CWS500N3 (band 2: 500 Hz - 1 kHz)
