Em test CWS500N3 (band 3: 1 kHz - 250 kHz)
The em test CWS500N3 (band 3: 1 kHz - 250 kHz) device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Em test CWS500N3 (band 3: 1 kHz - 250 kHz):
The frequency range of the Em test CWS500N3 (band 3: 1 kHz - 250 kHz) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Em test CWS500N3 (band 3: 1 kHz - 250 kHz).
Be careful changing these setting as RadiMation® is no longer able to verify if the Em test CWS500N3 (band 3: 1 kHz - 250 kHz) is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: em test CWS500N3 (band 3: 1 kHz - 250 kHz)
- Google image search: em test CWS500N3 (band 3: 1 kHz - 250 kHz)
