Emtest AN 2050N
The emtest AN 2050N device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Emtest AN 2050N:
The frequency range of the Emtest AN 2050N as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Emtest AN 2050N.
Be careful changing these setting as RadiMation® is no longer able to verify if the Emtest AN 2050N is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: emtest AN 2050N
- Google image search: emtest AN 2050N
