Emtest DCD-SR
The emtest DCD-SR device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Emtest DCD-SR:
The frequency range of the Emtest DCD-SR as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Emtest DCD-SR.
Be careful changing these setting as RadiMation® is no longer able to verify if the Emtest DCD-SR is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: emtest DCD-SR
- Google image search: emtest DCD-SR
