Exodus advanced communications AMP2044 Fwd
Jump to: navigation, search
The Exodus advanced communications AMP2044 Fwd device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Exodus advanced communications AMP2044 Fwd:
The frequency range of the Exodus advanced communications AMP2044 Fwd as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Exodus advanced communications AMP2044 Fwd.
Be careful changing these setting as RadiMation® is no longer able to verify if the Exodus advanced communications AMP2044 Fwd is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
