Exodus advanced communications AMP2102DB-5 Refl
Jump to: navigation, search
The Exodus advanced communications AMP2102DB-5 Refl device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Exodus advanced communications AMP2102DB-5 Refl:
The frequency range of the Exodus advanced communications AMP2102DB-5 Refl as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Exodus advanced communications AMP2102DB-5 Refl.
Be careful changing these setting as RadiMation® is no longer able to verify if the Exodus advanced communications AMP2102DB-5 Refl is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
