Frankonia AXL-200
Jump to: navigation, search
The Frankonia AXL-200 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Frankonia AXL-200:
The frequency range of the Frankonia AXL-200 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Frankonia AXL-200.
Be careful changing these setting as RadiMation® is no longer able to verify if the Frankonia AXL-200 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
ScreenElementDescription.png Efficiency The antenna efficiency factor of the antenna.
