Frankonia CDNE M2+M3
The Frankonia CDNE M2+M3 device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Frankonia CDNE M2+M3:
The frequency range of the Frankonia CDNE M2+M3 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Frankonia CDNE M2+M3.
Be careful changing these setting as RadiMation® is no longer able to verify if the Frankonia CDNE M2+M3 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Frankonia CDNE M2+M3
- Google image search: Frankonia CDNE M2+M3
