Frankonia CDN M2+M3-N
The Frankonia CDN M2+M3-N device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Frankonia CDN M2+M3-N:
The frequency range of the Frankonia CDN M2+M3-N as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Frankonia CDN M2+M3-N.
Be careful changing these setting as RadiMation® is no longer able to verify if the Frankonia CDN M2+M3-N is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Frankonia CDN M2+M3-N
- Google image search: Frankonia CDN M2+M3-N
