Frankonia CDN S25
Jump to: navigation, search
The Frankonia CDN S25 device driver is a Current Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Frankonia CDN S25:
The frequency range of the Frankonia CDN S25 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Frankonia CDN S25.
Be careful changing these setting as RadiMation® is no longer able to verify if the Frankonia CDN S25 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
