Frankonia ECU-6
Jump to: navigation, search
The Frankonia ECU-6 device driver is a Signal GeneratorCouplerPower MeterSwitch Matrix which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Frankonia ECU-6:
The frequency range of the Frankonia ECU-6 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Frankonia ECU-6.
Be careful changing these setting as RadiMation® is no longer able to verify if the Frankonia ECU-6 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
