Frankonia EFS-Laser
The Frankonia EFS-Laser device driver is a Field Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Frankonia EFS-Laser:
The frequency range of the Frankonia EFS-Laser as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Frankonia EFS-Laser.
Be careful changing these setting as RadiMation® is no longer able to verify if the Frankonia EFS-Laser is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Frankonia EFS-Laser
- Google image search: Frankonia EFS-Laser
