Frankonia FPA-26
Jump to: navigation, search
The Frankonia FPA-26 device driver is a Pre-Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Frankonia FPA-26:
The frequency range of the Frankonia FPA-26 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Frankonia FPA-26.
Be careful changing these setting as RadiMation® is no longer able to verify if the Frankonia FPA-26 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
