Frankonia FPA-6B
Jump to: navigation, search
The Frankonia FPA-6B device driver is a Pre-Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Frankonia FPA-6B:
The frequency range of the Frankonia FPA-6B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Frankonia FPA-6B.
Be careful changing these setting as RadiMation® is no longer able to verify if the Frankonia FPA-6B is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
