GAUSS INSTRUMENTS TDEMI 30M
Jump to: navigation, search
The GAUSS INSTRUMENTS TDEMI 30M device driver is a Power MeterSpectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the GAUSS INSTRUMENTS TDEMI 30M:
The frequency range of the GAUSS INSTRUMENTS TDEMI 30M as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the GAUSS INSTRUMENTS TDEMI 30M.
Be careful changing these setting as RadiMation® is no longer able to verify if the GAUSS INSTRUMENTS TDEMI 30M is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
TCPIP Connection
  • For the TCPIP-stream the correct connection string is: tcpip://<IP-ADDRESS>:21683 (where <IP-ADDRESS> is the network IP address and 21683 is the default port of the TDEMI).
  • For the VISA-stream the correct connection string for the Visa-ID is: TCPIP::<IP-ADDRESS>::21683::SOCKET (where <IP-ADDRESS> is the network IP address and 21683 is the default port of the TDEMI).
Auto step frequency
Frequency Bands
The CISPR tab of the GAUSS INSTRUMENTS TDEMI 30M allows to configure if the CISPR or non-CISPR detectors should be used during the measurements.
ScreenElementDescription.png Use CISPR detector Average (if applicable) If the checkbox is checked, the CISPR Average (indicated as the 'CAV' detector) will be used during the measurements. If the checkbox is not checked, the standard Average detector will be used.
ScreenElementDescription.png Use CISPR detector RMS (if applicable) If the checkbox is checked, the CISPR RMS (indicated as the 'CRMS' detector) will be used during the measurements. If the checkbox is not checked, the standard RMS detector will be used.
