GAUSS INSTRUMENTS TDEMI X40
The GAUSS INSTRUMENTS TDEMI X40 device driver is a Power Meter, Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the GAUSS INSTRUMENTS TDEMI X40:
The frequency range of the GAUSS INSTRUMENTS TDEMI X40 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the GAUSS INSTRUMENTS TDEMI X40.
Be careful changing these setting as RadiMation® is no longer able to verify if the GAUSS INSTRUMENTS TDEMI X40 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
TCPIP Connection
Auto step frequency
Frequency Bands
The CISPR tab of the GAUSS INSTRUMENTS TDEMI X40 allows to configure if the CISPR or non-CISPR detectors should be used during the measurements.
Use CISPR detector Average (if applicable) | If the checkbox is checked, the CISPR Average (indicated as the 'CAV' detector) will be used during the measurements. If the checkbox is not checked, the standard Average detector will be used. |
Use CISPR detector RMS (if applicable) | If the checkbox is checked, the CISPR RMS (indicated as the 'CRMS' detector) will be used during the measurements. If the checkbox is not checked, the standard RMS detector will be used. |
