Genistron Inc. GC151-40
The Genistron Inc. GC151-40 device driver is a Current Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Genistron Inc. GC151-40:
The frequency range of the Genistron Inc. GC151-40 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Genistron Inc. GC151-40.
Be careful changing these setting as RadiMation® is no longer able to verify if the Genistron Inc. GC151-40 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Genistron Inc. GC151-40
- Google image search: Genistron Inc. GC151-40
