Gigatronic 8541 Channel A
Jump to: navigation, search
The Gigatronic 8541 Channel A device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Gigatronic 8541 Channel A:
The frequency range of the Gigatronic 8541 Channel A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Gigatronic 8541 Channel A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Gigatronic 8541 Channel A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
