Hameg HMS1000
The Hameg HMS1000 device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Hameg HMS1000:
The frequency range of the Hameg HMS1000 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Hameg HMS1000.
Be careful changing these setting as RadiMation® is no longer able to verify if the Hameg HMS1000 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Hameg HMS1000
- Google image search: Hameg HMS1000
