Hameg HMS3010
Jump to: navigation, search
The Hameg HMS3010 device driver is a Power MeterSpectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Hameg HMS3010:
The frequency range of the Hameg HMS3010 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Hameg HMS3010.
Be careful changing these setting as RadiMation® is no longer able to verify if the Hameg HMS3010 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
