Hewlett Packard 3314 (External PM Modulation)
Jump to: navigation, search
The Hewlett Packard 3314 (External PM Modulation) device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Hewlett Packard 3314 (External PM Modulation):
The frequency range of the Hewlett Packard 3314 (External PM Modulation) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Hewlett Packard 3314 (External PM Modulation).
Be careful changing these setting as RadiMation® is no longer able to verify if the Hewlett Packard 3314 (External PM Modulation) is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
