Hewlett Packard 54510
The Hewlett Packard 54510 device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Hewlett Packard 54510:
The frequency range of the Hewlett Packard 54510 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Hewlett Packard 54510.
Be careful changing these setting as RadiMation® is no longer able to verify if the Hewlett Packard 54510 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Hewlett Packard 54510
- Google image search: Hewlett Packard 54510
