Hewlett Packard 7405A
Jump to: navigation, search
The Hewlett Packard 7405A device driver is a Power MeterSpectrum Analyser which is supported by RadiMation®.
Note: General information of this device driver can be found on the Hewlett Packard 7400 Series page.
The following tabs are available in the advanced configuration of the Hewlett Packard 7405A:
The frequency range of the Hewlett Packard 7405A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Hewlett Packard 7405A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Hewlett Packard 7405A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
