Hewlett Packard 752D
Jump to: navigation, search
The Hewlett Packard 752D device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Hewlett Packard 752D:
The frequency range of the Hewlett Packard 752D as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Hewlett Packard 752D.
Be careful changing these setting as RadiMation® is no longer able to verify if the Hewlett Packard 752D is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
