Hewlett Packard 8341A + 8116A (Alenia)
Jump to: navigation, search
The Hewlett Packard 8341A + 8116A (Alenia) device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Hewlett Packard 8341A + 8116A (Alenia):
The frequency range of the Hewlett Packard 8341A + 8116A (Alenia) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Hewlett Packard 8341A + 8116A (Alenia).
Be careful changing these setting as RadiMation® is no longer able to verify if the Hewlett Packard 8341A + 8116A (Alenia) is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
