Hewlett Packard 8350B (R&S AFG PM)
The Hewlett Packard 8350B (R&S AFG PM) device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Hewlett Packard 8350B (R&S AFG PM):
The frequency range of the Hewlett Packard 8350B (R&S AFG PM) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Hewlett Packard 8350B (R&S AFG PM).
Be careful changing these setting as RadiMation® is no longer able to verify if the Hewlett Packard 8350B (R&S AFG PM) is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Hewlett Packard 8350B (R&S AFG PM)
- Google image search: Hewlett Packard 8350B (R&S AFG PM)
