Hewlett Packard 85420E
The Hewlett Packard 85420E device driver is a Pre-Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Hewlett Packard 85420E:
The frequency range of the Hewlett Packard 85420E as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Hewlett Packard 85420E.
Be careful changing these setting as RadiMation® is no longer able to verify if the Hewlett Packard 85420E is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Hewlett Packard 85420E
- Google image search: Hewlett Packard 85420E
