Hewlett Packard 8561A
The Hewlett Packard 8561A device driver is a Power Meter, Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Hewlett Packard 8561A:
The frequency range of the Hewlett Packard 8561A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Hewlett Packard 8561A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Hewlett Packard 8561A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Hewlett Packard 8561A
- Google image search: Hewlett Packard 8561A
