Hewlett Packard 8566B
Jump to: navigation, search
Front view of a Hewlett Packard 8566B
Back view of a Hewlett Packard 8566B
The Hewlett Packard 8566B device driver is a Power MeterAD ConverterSpectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Hewlett Packard 8566B:
The frequency range of the Hewlett Packard 8566B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Hewlett Packard 8566B.
Be careful changing these setting as RadiMation® is no longer able to verify if the Hewlett Packard 8566B is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
