Hewlett Packard 8673B + 8130A
The Hewlett Packard 8673B + 8130A device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Hewlett Packard 8673B + 8130A:
The frequency range of the Hewlett Packard 8673B + 8130A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Hewlett Packard 8673B + 8130A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Hewlett Packard 8673B + 8130A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Hewlett Packard 8673B + 8130A
- Google image search: Hewlett Packard 8673B + 8130A
