Hewlett Packard 87301B
The Hewlett Packard 87301B device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Hewlett Packard 87301B:
The frequency range of the Hewlett Packard 87301B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Hewlett Packard 87301B.
Be careful changing these setting as RadiMation® is no longer able to verify if the Hewlett Packard 87301B is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Hewlett Packard 87301B
- Google image search: Hewlett Packard 87301B
