Holaday Instruments 4433-LFH
The Holaday Instruments 4433-LFH device driver is a Field Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Holaday Instruments 4433-LFH:
The frequency range of the Holaday Instruments 4433-LFH as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Holaday Instruments 4433-LFH.
Be careful changing these setting as RadiMation® is no longer able to verify if the Holaday Instruments 4433-LFH is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Holaday Instruments 4433-LFH
- Google image search: Holaday Instruments 4433-LFH
