Holaday Instruments 6105
The Holaday Instruments 6105 device driver is a Field Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Holaday Instruments 6105:
The frequency range of the Holaday Instruments 6105 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Holaday Instruments 6105.
Be careful changing these setting as RadiMation® is no longer able to verify if the Holaday Instruments 6105 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Holaday Instruments 6105
- Google image search: Holaday Instruments 6105
