IFI CMC 250
Jump to: navigation, search
The IFI CMC 250 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the IFI CMC 250:
The frequency range of the IFI CMC 250 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the IFI CMC 250.
Be careful changing these setting as RadiMation® is no longer able to verify if the IFI CMC 250 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
