IFI DC100F
Jump to: navigation, search
The IFI DC100F device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the IFI DC100F:
The frequency range of the IFI DC100F as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the IFI DC100F.
Be careful changing these setting as RadiMation® is no longer able to verify if the IFI DC100F is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
