IFI DC100H
The IFI DC100H device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the IFI DC100H:
The frequency range of the IFI DC100H as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the IFI DC100H.
Be careful changing these setting as RadiMation® is no longer able to verify if the IFI DC100H is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: IFI DC100H
- Google image search: IFI DC100H
