IFI SMCC 350
The IFI SMCC 350 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the IFI SMCC 350:
The frequency range of the IFI SMCC 350 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the IFI SMCC 350.
Be careful changing these setting as RadiMation® is no longer able to verify if the IFI SMCC 350 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: IFI SMCC 350
- Google image search: IFI SMCC 350
