IFR 2024B
Jump to: navigation, search
The IFR 2024B device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the IFR 2024B:
The frequency range of the IFR 2024B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the IFR 2024B.
Be careful changing these setting as RadiMation® is no longer able to verify if the IFR 2024B is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
