IFR 2398
Jump to: navigation, search
The IFR 2398 device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the IFR 2398:
The frequency range of the IFR 2398 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the IFR 2398.
Be careful changing these setting as RadiMation® is no longer able to verify if the IFR 2398 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
