Kalmus 7150LC-S-CE Reflected Power Meter
Jump to: navigation, search
The Kalmus 7150LC-S-CE Reflected Power Meter device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Kalmus 7150LC-S-CE Reflected Power Meter:
The frequency range of the Kalmus 7150LC-S-CE Reflected Power Meter as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Kalmus 7150LC-S-CE Reflected Power Meter.
Be careful changing these setting as RadiMation® is no longer able to verify if the Kalmus 7150LC-S-CE Reflected Power Meter is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
