Keysight N4985A
The Keysight N4985A device driver is a Pre-Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Keysight N4985A:
The frequency range of the Keysight N4985A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Keysight N4985A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Keysight N4985A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Keysight N4985A
- Google image search: Keysight N4985A
