Keysight Technologies 33621A
Jump to: navigation, search
The Keysight Technologies 33621A device driver is a Signal GeneratorModulation Source which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Keysight Technologies 33621A:
The frequency range of the Keysight Technologies 33621A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Keysight Technologies 33621A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Keysight Technologies 33621A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
