Keysight Technologies E5061B
The Keysight Technologies E5061B device driver is a Power Meter, Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Keysight Technologies E5061B:
The frequency range of the Keysight Technologies E5061B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Keysight Technologies E5061B.
Be careful changing these setting as RadiMation® is no longer able to verify if the Keysight Technologies E5061B is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Keysight Technologies E5061B
- Google image search: Keysight Technologies E5061B
